It does not always bring in data from ecel correctly. I would just create a geodatabase and import the table and add new fields and then calculate them to the correct format that you need. Good Luck Tom
Thanks a lot. Your procedure run !!! But ...I have some problem with some field data type.The original data are from an Excel file. In the original file some coloumn are numeric (I choose numeric format from the FormatCell - right click) but when I load the spreendsheet in ArcMap the same data are converted in text. WHY ???I can't understand the motive. I checked for the right decimal delimiting carachter or the presence of '. Nothing to do.Is it possible to change the field data type in a Table or Feature Class in ArcGIS ?
You can't just load a table into a feature class. You will have to add the table to ArcMap then right click on it and say Plot XY data and specify the X and Y fields (Lat & Long). Once it plots that information you should be able to take that and load it into your geodatabase. Tom
