faultCode:null faultString:'Error #2032: Stream Error. URL:https://gis.blahblahblah.com/arcgis/tokens?tokens' faultDetail:'null'
Are you able to generate a token from the HTML form at:https://gis.blahblahblah.com/ArcGIS/tokens/
Try setting the tokenServiceURL to:https://gis.blahblahblah.com/ArcGIS/tokens/generateToken
What was the request for this response? If the response code is 200, then this response should not be generating a "Error #2032: Stream Error".
Can you use HttpFox to see what the requests and responses are?
Try setting the tokenServiceURL to the same as what you see on your server at /arcgis/rest/info
