Can anyone tell me why Copy Selected Records might be disabled, and what I can do about it?
Ctrl-Shift-C has no effect.
Selected features are in a polygon feature class in file geodatabase that only I have access to. Editing is enabled.
Pro v2.4.0.
Some fields were hidden and Show Aliases was turned on. After unhiding all fields and turning off aliases I can copy. It took several seconds for the [Copy] button to enable itself, perhaps 5.
I tried hiding the fields again and [Copy] remains enabled (and functional).
Copy remains enabled after exiting Pro and restarting again.
Thanks for pointing me in the right direction!
It's a table for a polygon feature class within a feature dataset, in a file-gdb stored on network windows share.
No joins, domains, or sub-types.
I'm not sure why the strange ObjectID field name. It's not something I named deliberately. I believe the FC originally came from an AutoCAD file so it's likely something to do with that heritage.
No, no warnings or alerts
your objectid field is a bit strange.
Edit an active table—ArcGIS Pro | ArcGIS Desktop see the section on the importance of the objectid field
What is the nature of this table?
Are some fields hidden? A join?
Is it a standalone geodatabase table?
https://community.esri.com/migrated-users/105923
In your Table of Contents click on the List By Editing (the pencil). Are there any Warnings or Alerts for the feature you are trying to copy?
