how can I create identical copy of my sde Dataset? I need to use it as a test version.
it contains feature classes, relationship and much more.
If you need it in the same geodatabase just Copy/Paste the feature dataset. It will append the <name>_1 to each of the layers copied.
Hello @George Thompson,
thanks for your reply.
And if I do want it as an extra sde dataset? not in the same geodatabase?
You can also use copy/paste for that.
Note: the permissions, versioning information (delta tables) will NOT be copied over via that process. I am not aware of a way to copy all that with our tools.
thanks again. But I need to have created "empty" sde to copy/paste all things inside? Or I do select all elements, copy them and paste... where?
Sorry for questions but I am quite new in it.
Thanks a lot!
