Has anyone encountered an issue with World Geocoder for ArcGIS when using it in your surveys??
My specific issue is that I cannot get the survey to call to the World Geocoding endpoint if the survey is being sent from within our Dev-portal(EP Developer role). It returns blank address information.
However, when I publish the same survey from my company AGOL (Publisher role), the geocoder works as expected and auto populates the address.
I'm on Survey123 v2.6.7 and Survey123 Connect v3.3.51
I've attached a sample of the .xls form to show the call format.
