I have a legacy feature dataset which was created with custom xy resolution. The person who created it, added a bunch of zeros behind the decimal. This seems to be causing some adverse affects to the network trace geoprocessing tool. I cannot replace the dataset as of right now, but I would like to at least replicated it to another database for a while.
My question is: If I set up a new feature dataset using the default xy resolution, will I be able to use one-way replication from the high res dataset to the default res dataset?
