I am trying to Generate a report using Survey123, failing to do so, getting an error message:
"Failed to print map for ${Report_point}. Failed to load web map: Unable to load https://arcgis.thiess.com/arcgis/rest/services/TestPublish/sonReport/FeatureServer/0?f=json status: 0"
I am uisng ArcGIS enterprise login and SQL database.
Kindly help? Please let me know if need more clarification.
Hi Vaibhav,
Is the ArcGIS Enterprise site accessible from the internet (i.e., can you log in to ArcGIS Enterprise when not in your company's network or VPN'ed in)? The Feature Report service only supports Enterprise installations that are accessible from the internet.
Its external facing
Did you specify a map by id in the template? Could I ask you to try a sample that does not have a map in it to make sure that is created properly?
Hi James,
Thanks for taking interest in the query.
Yes, It did work if I don't have a map in the template. But my requirement as such requires one (map). I tried with specifying the Web map by id in the template, hence it keeps giving me the follwoing error:
"Failed to print map for ${Report_point|mapSettings:"2df5cba97dc940b7998210cebae90956":100000|size:400:400}. Failed to load web map: Unable to load https://arcgis.thiess.com/arcgis/rest/services/TestPublish/sonReport/FeatureServer/0?f=json status: 0Please see details in the recent tasks panel
hi, check this blog https://community.esri.com/groups/survey123/blog/2019/06/28/world-ufo-day-release-35 .
Today, when I signed in the Survey123 website (As ArcGIS Enterprise user- https://survey123.arcgis.com/?portalUrl=https://exampleportal.esri.com/arcgis) when I click on feature report (which has changed from Report-beta to Feature report) through an error says,- Your ArcGIS Online subscription is not active. Contact your organization administrator for assistance.
Wondering being an ArcGIS enterprise user why do I receive this error.
Can you please answer the following questions?
1. What version of ArcGIS Enterprise are you using?
2. What type of identity store is the portal setup with? (i.e. Built-in or Enterprise)
3. If Enterprise, is it using IWA or PKI?
Please give as many details as you can about your environment and confirm that this was working successfully prior to the latest release.
Brandon
Thank you for taking an interest in the problem.
Below is the answer to your questions:
I am using the latest version of ArcGIS Enterprise ie 10.7.1,
Enterprise Identity store.
Using SAML 2.0
