I was trying to read a CAD feature class from a DWG file but could not find any Pro APIs related to it. Any help will be greatly appreciated!
Hi Fayu
Do you mean Pro’s Map Control? Yes, should be no problem.
Uma
Hi Uma,
Thank you very much for your help. Is it possible to a CAD file without add it to Map control?
Best regards,
Fayu
Hi
Here is a code snippet to add a feature class in a CAD DWG file -
<SPAN class="keyword token">string</SPAN> url <SPAN class="operator token">=</SPAN> <SPAN class="string token">@"E:\Data\CAD\Charlottesville\N1W1.dwg\Polyline"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//FeatureClass of a cad dwg file</SPAN> Uri uri <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN>url<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">await</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> LayerFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateLayer</SPAN><SPAN class="punctuation token">(</SPAN>uri<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
