One has to go the numpy route?
import numpy as np import arcpy #source http://forums.arcgis.com/threads/865-quot-built-in-quot-rasters-in-python-map-algebra #with some fiddling # Setup some rasters of rows and columns # (like old $$ROWMAP and $$COLMAP) arcpy.env.workspace = "c:/temp" arcpy.env.overwriteOutput = 1 nprows = np.indices((10,10))[0] npcols = np.indices((10,10))[1] # Convert the numpy arrays to ESRI rasters (ie Raster objects) # called 'rows' and 'cols' row_ras = arcpy.NumPyArrayToRaster(nprows) row_ras.save("rowraster") col_ras = arcpy.NumPyArrayToRaster(npcols) col_ras.save("colraster") print row_ras print col_ras
import arcgisscripting gp = arcgisscripting.create(9.3) #This works in ArcGIS 10!!! expr=gp.getparameterastext(0) output=gp.getparameterastext(1) result=gp.SingleOutputMapAlgebra(expr,output)
The best workaround I found in that environment was to compute flow accumulations for constant direction grids (and unit weights): $$ColMap is the flow accumulation of a grid filled with 1's and $$RowMap is the flow accumulation of a grid filled with 4's.
I did an implementation of this idea in arcpy map algebra here:arcpy map algebra $$ROWMAP, $$COLMAP
Luke -- arcgisscripting is still there under arcpy. (You probably know this by know as this post was 2011!)
So this works (for now anyway).
import arcpy arcpy.env.scratchWorkspace = r"D:\Users\cprice\work" arcpy.CheckOutExtension("spatial") arcpy.env.extent = arcpy.Extent(0, 0, 10, 10) arcpy.env.cellSize = 1 arcpy.gp.SingleOutputMapAlgebra_sa("$$ROWMAP"), "rowmap")
