We just set up a new SDE on SQL Server 2017 and ArcGIS Enterprise 10.6.1 . We are having SDE lock issues.
Nearly every time we go to edit something on the SDE, we can not edit it because of a lock. Even after removing all locks from the database, it will still say it is locked. Sometimes going into the SDE and clearing out all the lock tables works, other times it does not.
Is there anything that could be causing this?
Thanks!
