I've created a survey using Survey123 for our city arborist to create a tree inventory. It uses a lot of features that are unique to Survey123 that make it far superior to a Collector app. However, there is one issue that I haven't found a solution to. When using the geopoint question in the survey, is there any way to see the points in the feature class that have already been collected on the map? We've been running into a problem where our arborist isn't sure which trees already have a completed survey and so finds himself resurveying trees that he's already done.
One workaround that I've looked into is having him collect the geometry using Collector and linking to Survey123 using custom URL parameters but this doesn't work because it creates a new feature rather than editing the attributes of the existing feature.
Does anyone have ideas how I can integrate a map showing the existing collected points into a Survey123 survey?
