Hello, I'm trying to locate on the map a geographic coordinate. I haven't been able to find a ProSnippet, arcgis pro sdk community samples or any other example that can give me clues on how to do it.#arcgisprosdk #csharp #addin #coordinate #mappoint
Hi Andreas, can you be more specific please? You want to....zoom, pan to the location, select something at a location, show a dot (or similar) on a map "at" the location or...?
I am creating a tool that would zoom in on specific geographic points. My idea is to have the list of geographic points with their geographic coordinates which the tool should convert to the current map mappoints, but as said I'm a bit clueless on how to go about.
I created a MapPoint then used this code:
var coords = GeometryEngine.Project(theMapPoint, SpatialReferences.WGS84) as MapPoint;
_pointSymbol = SymbolFactory.ConstructPointSymbol(ColorFactory.RedRGB, 6, SimpleMarkerStyle.Circle);
AddOverlayAsync(coords, _pointSymbol.MakeSymbolReference());
ActiveMapView.ZoomTo(theMapPoint);
What is theMapPoint? Is it a point selected from the map? If so, that's not what I need. I need a way to convert geographic coordinates into MapPoints.
Hi Andreas, might I suggest starting here:
Create MapPoint
https://github.com/esri/arcgis-pro-sdk/wiki/ProSnippets-Geometry#construct-a-mappoint
Projection:
https://github.com/esri/arcgis-pro-sdk/wiki/ProSnippets-Geometry#project-from-wgs84-to-webmercator
Zoom, Pan, etc.
https://github.com/esri/arcgis-pro-sdk/wiki/ProSnippets-MapExploration#zoom-to-an-extent
and so, one example might be.....
QueuedTask.Run(() => {
//Create a point
var pt = MapPointBuilder.CreateMapPoint(x,y,SpatialReferenceBuilder.CreateSpatialReference(4326)); //Buffer it - for purpose of zoom var poly = GeometryEngine.Buffer(pt, buffer_size);
//do we need to project the buffer polygon?
if (!MapView.Active.Map.SpatialReference.IsEqual(poly.SpatialReference)) { //project the polygon poly = GeometryEngine.Project(poly, MapView.Active.Map.SpatialReference); }
//Zoom - add in a delay for animation effect MapView.Active.ZoomTo(poly,new TimeSpan(0, 0, 0, 3));
