In last version of Survey123 (2.2.14) there is no more "compact" option in the validation list for appearance types, applicable to a "begin group question" as you can read from this help page: Appearance—Survey123 for ArcGIS | ArcGIS
Probably a bug?
Workaround: insert manually this value and update Excel validation list for "Appearance field"
Hi Stefano - Can you confirm that this was for creating a survey from an existing service?
You can add the 'compact' appearance by:
Hi Stefano
If you want to get access to Compact (and other newer tags) on the template used when creating a survey from an existing feature service - you must ensure that the following file is deleted before you install a new version of Connect:
XLSFormTemplate.xlsx
In Windows you can find the file here:
C:\users\xyz\AppData\Local\Temp
Currently the app will not overwrite the template with the newer one contained in the installer (we will fix this).
Hi Johnathan, I confirm that this Survey was created from existing service.
After you tell me this I've tried to create a survey123 from scratch using "Advanced model" and I found missing voices. Thanks!
