I have a query widget that queries a view table on ArcGIS REST. In the widget.js file, I am building a whereclause with the widget parameters and using QueryTask to query the database. I need to run two instances of QueryTask, the second takes a lot of time because it has to use statistical results from each row from the 1st query by looping through (67 times) to build an array of rows. [ [...], [...], [...] ]. I then need to format the results of the results array and create a layer. All of this works, except that I
