So what you're essentially saying is that the tool does the whole Geostatistical Wizard process (including semivariogram/covariance modeling, selecting the optimal lag size/other parameters, etc.) for you based on the model you feed it (i.e., you're essentially just telling it, "use XYZ interpolation method on this dataset"?)?
OR are you telling it to use XYZ interpolation method on this dataset with this specific nugget value, this specific lag size, etc. (where the specific nugget value, lag size, etc. are the actual numbers from the model you feed it, which is based on a different dataset)?
It seems like the second option would produce inaccurate results, but it would be helpful to have clarification as to how the tool actually works on its help page.
Hi, Erik
I have another question for Kringing Geostatistical Wizard. Can I set the lower and upper values for the results of Kriging interpolation? Thanks!
This workflow is really only suggested when you know that the new datasets will have the same general structure. Applying the same parameters to datasets that are different (ie, the presence and absence of trends) is not a good idea.
As for trend removal, the idea is to first do a very basic polynomial interpolation to remove the general trends, then you do kriging on the autocorrelation that is left over. The idea is that there is a general trend in the data, but there is also correlated variability around that trend. Trend removal takes care of the first part, and kriging takes care of the second part. In essence, you are interpolating twice, but the first time is only for general trends in the data.
When I use the Geostatistical Wizard, I set some parameters, which confused me a lot.
Thanks a lot!
Thanks a lot. Here I have a question. How can I apply the geostatistical layer which created by Create Geostatistical Layer to the measurements of the new day?
The key is that you can apply the interpolation parameters to a new dataset. Indeed, it doesn't make much sense to apply it to the same data (this would just make a copy of the layer). Here is a typical scenario that shows how this tool can be useful:
You have a monitoring network set up to take daily measurements of pollution levels. Each day, these sensors measure the pollution and store it into a database, and each day you want to create an interpolated map of pollution levels. On the first day, you take a lot of time to create a quality kriging model in the Geostatistical Wizard and output a geostatistical layer. On the next day, you can use this layer as the model source in Create Geostatistical Layer and apply the kriging parameters to the measurements of the new day. By reusing the original geostatistical layer for the data of each new day, you can fully automate this process and not have to manually go into the Geostatistical Wizard every day to create your map.
Hi, Eric
When I read your post, I am confused about these two layers, what is the difference between two layers: the existing geostatistical layer and the new one, which we create using the Create Geostatistical Layer tool. I mean we already created on using Geostatistical Wizard, why we need to use Create Geostatistical Layer tool to create a new one.
Thank you.
What I seem to have stumbled across so far is that you can use Geostatistical Analyst/Explore Data to get an insight into the spatial distribution of point vector data and you can convert raster layers into geostatistical layers using the Geostatistical Wizard in Geostatistical Analyst. Then you can use these Geostatistical Layers as input to the Geostatistical Tools in Arc ToolBox. Am I right so far?
