Not sure if ArcGISOnline is different than a local AGS, but I don't see the respective MapService for that FeatureService (normally, there is one of each when you make a featureservice).In any case, since it is featureservice, this is the only way I could get it to display in the viewer:<layer label="Northern Pike YOY" type="feature" visible="true" alpha="1" url="http://services.arcgis.com/F7DSX1DSNSiWmOqh/ArcGIS/rest/services/WIFO_GBT_PIKE/FeatureServer/0"> </layer> <layer label="Northern Pike Spawn Adults" type="feature" visible="true" alpha="1" url="http://services.arcgis.com/F7DSX1DSNSiWmOqh/ArcGIS/rest/services/WIFO_GBT_PIKE/FeatureServer/1"> </layer> <layer label="Northern Pike Unk" type="feature" visible="true" alpha="1" url="http://services.arcgis.com/F7DSX1DSNSiWmOqh/ArcGIS/rest/services/WIFO_GBT_PIKE/FeatureServer/2"> </layer> But, it does draw them correctly (at least in v3 and v31. Don't have older version to test).R_
I don't use agsonline, so not sure if it is structured the same, but.. Does the above change work for you?R_
Hi, I was wondering if anyone could help me set up config.xml correctly to reference an ArcGIS Online feature service with three sublayers, since I haven't been able to get the data to appear in the viewer. I tried the following to no avail to incorporate all three sublayers: <layer label="Northern Pike" type="dynamic" visible="true" alpha="1" url="http://services.arcgis.com/F7DSX1DSNSiWmOqh/arcgis/rest/services/WIFO_GBT_PIKE/ MapServer"> </layer> I then tried to do for a single sublayer to see if type="feature" would make it work: <layer label="Northern Pike" type="feature" visible="true" alpha="1" url="http://services.arcgis.com/F7DSX1DSNSiWmOqh/arcgis/rest/services/WIFO_GBT_PIKE/FeatureServer/0"> </layer> Any suggestions? Thanks in advance for your help!
Hi,I was wondering if anyone could help me set up config.xml correctly to reference an ArcGIS Online feature service with three sublayers, since I haven't been able to get the data to appear in the viewer. I tried the following to no avail to incorporate all three sublayers:<layer label="Northern Pike" type="dynamic" visible="true" alpha="1" url="http://services.arcgis.com/F7DSX1DSNSiWmOqh/arcgis/rest/services/WIFO_GBT_PIKE/FeatureServer"></layer>I then tried to do for a single sublayer to see if type="feature" would make it work:<layer label="Northern Pike" type="feature" visible="true" alpha="1"url="http://services.arcgis.com/F7DSX1DSNSiWmOqh/arcgis/rest/services/WIFO_GBT_PIKE/FeatureServer/0"></layer>Any suggestions?Thanks in advance for your help!
