Anyone,
Is there a tutorial that goes through registering ArcGIS Online as a data store within GeoEvent Extension?
Thank you!
--Adam
For those interested, I got an email answering this question. I will quote it. It is pretty straightforward, although there is no tutorial that walks through it.:
The dialog / workflow does not appear to have changed between10.2.2 and 10.3:
- From the Site > Data Stores page in GeoEvent Manageryou should select to ‘Register ArcGIS Server’
- Select the ‘AGOL’ radio button to specify that you’reregistering an connection to ArcGIS Online
- You should only need to enter:
o A name for the connection (e.g. My_AGOL)
o A username / password used to log-in toyour Organization
o The default update interval is 5 minutes
- Click ‘Register’
If you want to test to see if you’ve successfully registered theconnection to the server, try importing a GeoEvent Definition. You should beable to select your registered Server connection to the AGOL Organization anddiscover any hosted feature services / feature layers in existing servicefolders.
Thank you!!!
