Hello!
I am a beginner in GIS and would like to create a representation of migration across borders. Can anyone recommend a "how to" resource?
I would like to show the movement from provinces, districts and/or towns.
In case you don't want to have straight lines you could do something like this (black lines are the curves created in the script):
... using a little of Python code (ugly, I know, but will clean it up and convert it into a toolbox later...)
import arcpy import math def main(): tbl = r"D:\Xander\GeoNet\MigrationRoutes\gdb\test.gdb\test_tbl" fc_out = r"D:\Xander\GeoNet\MigrationRoutes\gdb\test.gdb\migration06" sr = arcpy.SpatialReference(28992) flds = ("X1", "Y1", "X2", "Y2") curvature = 0.05 # 5% pnts_on_curve = 100 lst_lines = [] with arcpy.da.SearchCursor(tbl, flds) as curs: for row in curs: pnt1 = arcpy.Point(row[0], row[1]) pnt2 = arcpy.Point(row[2], row[3]) line = arcpy.Polyline(arcpy.Array([pnt1, pnt2]), sr) length = line.length offset = curvature * length delta_x = row[2] - row[0] delta_y = row[3] - row[1] # extract points on line arr = arcpy.Array() for i in range(0, pnts_on_curve + 1): frac = i / float(pnts_on_curve) pnt = line.positionAlongLine(frac, use_percentage=True) line_perp = perpendicular_line(line.firstPoint, line.lastPoint, pnt.firstPoint) asin = math.sin(frac * math.pi) dist_off = offset * asin pnt_new = line_perp.positionAlongLine(dist_off, use_percentage=False) arr.add(pnt_new.firstPoint) line_new = arcpy.Polyline(arr, sr) lst_lines.append(line_new) arcpy.CopyFeatures_management(lst_lines, fc_out) class Coord(object): def __init__(self,x,y): self.x = x self.y = y def __sub__(self,other): # This allows you to substract vectors return Coord(self.x-other.x,self.y-other.y) def __repr__(self): # Used to get human readable coordinates when printing return "Coord(%f,%f)"%(self.x,self.y) def length(self): # Returns the length of the vector return math.sqrt(self.x**2 + self.y**2) def angle(self): # Returns the vector's angle return math.atan2(self.y,self.x) def normalize(coord): return Coord( coord.x/coord.length(), coord.y/coord.length() ) def perpendicular(coord): return Coord( coord.length()*math.cos(coord.angle()+math.pi/2), coord.length()*math.sin(coord.angle()+math.pi/2) ) def perpendicular_line(coord_from, coord_to, coord_at): length = math.hypot(coord_from.X - coord_to.X, coord_from.Y - coord_to.Y) a = Coord(coord_from.X, coord_from.Y) b = Coord(coord_to.X, coord_to.Y) perp = perpendicular(normalize(a-b)) perp_len = Coord(perp.x*length, perp.y*length) coord_perp = Coord(perp_len.x+coord_at.X, perp_len.y+coord_at.Y) return arcpy.Polyline(arcpy.Array([coord_at, arcpy.Point(coord_perp.x, coord_perp.y)])) if __name__ == '__main__': main()
Thank you for this information. I will make x,y tables and see if I can get this to work. I am using arcmap 10.1, and I have not used Python yet. Now I will take a class in how to apply it.
-Rich
Sent from Windows Mail
Thank you for the tool. This looks like what I need. I will give it a try and let you know.
Find attached the toolbox. In case of any problems, please post them back. The toolbox was created with ArcGIS 10.3.
If you have a table with the X,Y (or lat, lon) of the from and to locations on a single record you can use the XY To Line (Data Management) tool. This will create straight lines between the from and to locations. The bad thing about this is that if you have migration between two locations in both directions, it will overlap.
