I'm working on a search function that selects features from a local runtime geodatabase on the device and am currently trying to call an error message when the function fails to return any features.
There was a section in a tutorial for querying features that i found which has a response in the GeodatabaseFeatureTable component of the queried table but this section of code never got called (I loaded in console.log() statements which were never displayed when I tested the code). This used an if statement that's similar to the one below:
if(queryFeaturesResult.iterator.hasNext===0){
message1.visible=true
}<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>The other method that I've tried to call the error message from is the FeatureLayer component by checking the number of selected features when selection query is called however this only loads the message on the clearSelection() function or doesn't load at all.
Is there any other way to check for the number of returns?
I've copied in the related code below.
MainApp{
GeodatabaseFeatureTable {
geodatabase: geodatabase.valid ? geodatabase: null
featureServiceLayerId: 0
Map {
FeatureLayer{
featureTable: tableAddress
visible:false
function selectID(){
var buffer = selectedFeatures[0].geometry.buffer(50, "Meters")
var featureLength = selectedFeatures.length
if(featureLength === 0){
message1.visible = true
} else if (featureLength === 1){
map.zoomTo(buffer)
} else {
message2.visible = true
onSelectedFeaturesChanged: {
selectID()
SearchFunction {
anchors {
left: parent.left
right: parent.right
top: headerRect.bottom
TextField {
anchors {
left: parent.left
bottom: parent.bottom
margins: 8
width: 2*(parent.width/3)
height: 50
placeholderText: "2 Fryatt Quay, Wellington"
Button {
text: "Find"
enabled: searchQuery.length != 0
anchors {
right: searchClose.left
margins: 8
Query{
where: "\"ADDRESS\" = \'"+ searchQuery.text.toUpperCase()+"\'"
Query{
where: "\"FULL_RD_NM\" = \'" + searchQuery.text + "\'"
FeatureResult {
onClicked: {
if (searchTable.currentText === "Addresses"){
address.clearSelection()
address.selectFeaturesByQuery(searchQAddress,Enums.SelectionMethodNew)
console.log(searchQAddress.where)
} else if (searchTable.currentText === "Roads"){
road.selectFeaturesByQuery(searchQRoads,Enums.SelectionMethodNew)
Button {
text: "Close"
anchors {
right: parent.right
margins: 8
onClicked: {
closeSearch.running = true
searchFunction.enabled = false
}<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
