navToolbar.zoomToFullExtent.toString()
"function () { var map = this.map; map.setExtent(map.getLayer(map.layerIds[0]).initialExtent); }"
navToolar.zoomToFullExtent = function() { var map = this.map; map.setExtent(appFullExtent); }
You can take a look at the code for zoomToFullExtent by typing this in firebug or chrome dev tools console: navToolbar.zoomToFullExtent.toString() That will print: "function () { var map = this.map; map.setExtent(map.getLayer(map.layerIds[0]).initialExtent); }" The easiest way to change this is to re-define zoomToFullExtent for your toolbar. After you create your toolbar, do something like this: navToolar.zoomToFullExtent = function() { var map = this.map; map.setExtent(appFullExtent); } Where appFullExtent is a global that represents your app's full extent.
navToolbar = new Navigation(map); on(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler); registry.byId("zoomin").on("click", function(){ navToolbar.activate(Navigation.ZOOM_IN); }); registry.byId("zoomout").on("click", function(){ navToolbar.activate(Navigation.ZOOM_OUT); }); registry.byId("zoomfullext").on("click", function(){ navToolbar.zoomToFullExtent(); }); registry.byId("zoomprev").on("click", function(){ navToolbar.zoomToPrevExtent(); }); registry.byId("zoomnext").on("click", function(){ navToolbar.zoomToNextExtent(); }); registry.byId("pan").on("click", function(){ navToolbar.activate(Navigation.PAN); }); registry.byId("deactivate").on("click", function(){ navToolbar.deactivate(); }); function extentHistoryChangeHandler(){ registry.byId("zoomprev").disabled = navToolbar.isFirstExtent(); registry.byId("zoomnext").disabled = navToolbar.isLastExtent(); } });
