Dear community
I am working with ArcGIS API for JavaScript 4.4 und would like to create a map with a basemap in the background and my own features in foreground, which are in "Gauss-Krueger-4" coordinate systen (epsg: 31468).
Now to my questions: Can the ArcGIS Basemap be displayed just in WGS84-system? Or is it possible to display it also in GK4?
Do I have to transform my GK4 data into WGS84?
Below you can see my code. The map sets automatically WGS84 - obvisously immediately after displaying the basemap. Because of that, my GK4 coordinates can't be zoomed on. What am I doing wrong?
Thank you very much for looking up. Perhaps somebody knows the answer.
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/domReady!"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"streets"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// Reference to the DOM node that will contain the view</SPAN>
map<SPAN class="punctuation token">:</SPAN> map <SPAN class="comment token">// References the map object created in step 3</SPAN>
view<SPAN class="punctuation token">.</SPAN>extent <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Extent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
xmin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4400000.0</SPAN><SPAN class="punctuation token">,</SPAN>
ymin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">5335500.0</SPAN><SPAN class="punctuation token">,</SPAN>
xmax<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4413500.0</SPAN><SPAN class="punctuation token">,</SPAN>
ymax<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">5346000.0</SPAN><SPAN class="punctuation token">,</SPAN>
spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">31468</SPAN>
view<SPAN class="punctuation token">.</SPAN>center <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">4409051.287</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">5341122.644</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
view<SPAN class="punctuation token">.</SPAN>zoom <SPAN class="operator token">=</SPAN> <SPAN class="number token">14</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
