Yes, it looks the exact same.i can RUN some of the layers.
Can you confirm you Flex Build and flex complier look something like the attached>>>??
Are you using the Adobe Flex 4.0 API?should be in your "flex Build Path" along with the agslib-2.0betaUpdate3-2010-05-18.swc
Hi Jessica,I am not sure what the problem is...could you provide some more detail as to you setup;-API version,-flex api version 3.5/4...-flash/flex builder ?And what application you are trying to run... felx viewer 1.3??
I am trying to load the ArcGIS Flex file from the website, it downloaded the data fine. I follow the readme, and once i go to hit RUN....its tells me "Errors in workspace" I attempt to PROCEED, but nothing loads. Please help, i am new to this program, but i can follow a Readme...thanks!!
