# Usage: LineToProjectTransaction <Distance> <Feature_Set> <xxbuf_shp> # Description:# Add Agency Projects to the master GIS Project database that are best mapped as linear features such as road or utility corridors. # User enters the project transaction year, project number, and their initials, then digitizes a line on the map. A 100 foot wide buffer polygon is calculated from the digitized line.# The buffer polygon is appended with attributes to Transaction_poly layer in GIS_MAD sde db.# ---------------------------------------------------------------------------# Import arcpy moduleimport arcpy# Script argumentsProject_Year = arcpy.GetParameterAsText(0)if Project_Year == '#' or not Project_Year: Project_Year = "2013" # provide a default value if unspecifiedProject_Number_eg_0025 = arcpy.GetParameterAsText(1)Your_initials = arcpy.GetParameterAsText(2)Distance = arcpy.GetParameterAsText(3)if Distance == '#' or not Distance: Distance = "50 Feet" # provide a default value if unspecifiedInput_Line = arcpy.GetParameterAsText(4)if Input_Line == '#' or not Input_Line: Input_Line = "M:\\ApaGis\\Scratch\\scratch.gdb\\xxline2" # provide a default value if unspecifiedTransactionPoly2 = arcpy.GetParameterAsText(5)if TransactionPoly2 == '#' or not TransactionPoly2: TransactionPoly2 = "Database Connections\\GIS_MAD.sde\\GIS_MAD.DBO.Transaction_Poly" # provide a default value if unspecified# Local variables:xxbuffer = "M:\\ApaGis\\Scratch\\scratch.gdb\\xxbuf"GIS_MAD_DBO_Transaction_Poly = "Database Connections\\GIS_MAD.sde\\GIS_MAD.DBO.Transaction_Poly"APANUMBER = "'"+'P'+Project_Year+"-"+Project_Number_eg_0025.upper()+"'"# Check for the existance of in_memory\\BufferedLine output data before running Buffer.if arcpy.Exists("M:\\ApaGis\\Scratch\\scratch.gdb\\xxbuf"): arcpy.Delete_management("M:\\ApaGis\\Scratch\\scratch.gdb\\xxbuf")# Process: Bufferarcpy.Buffer_analysis(Input_Line, xxbuffer, Distance, "FULL", "FLAT", "NONE", "")# Process: Calculate Transaction Typearcpy.CalculateField_management(xxbuffer, "TRANSACTIONTYPE", "'P'", "PYTHON", "")# Process: Calculate APA Numberarcpy.CalculateField_management(xxbuffer, "APANUMBER", APANUMBER, "PYTHON", "")# Process: Calculate Data Entry Datearcpy.CalculateField_management(xxbuffer, "FEATUREDATE", "datetime.datetime.now( )", "PYTHON", "")# Process: Calculate Feature Sourcearcpy.CalculateField_management(xxbuffer, "FEATURESOURCE", "'20'", "PYTHON", "")# Process: Calculate Staffarcpy.CalculateField_management(xxbuffer, "STAFF", '"'+Your_initials.upper()+'"', "PYTHON", "")# Process: Appendarcpy.Append_management(xxbuffer, GIS_MAD_DBO_Transaction_Poly, "No_TEST", "", "")# Process: Deletearcpy.Delete_management(Input_Line)# Process: Deletearcpy.Delete_management(xxbuffer)arcpy.RefreshActiveView()
