Is it possible to change the numbers/text in the ArcGIS Online Hosted story map series - bulleted layout? I'm trying to imitate the Smithsonian bullet text below. I'm afraid using the configurable app is a bit beyond me...
Unfortunately you will not be able to do this with the hosted version of the bulleted layout. You would need to download the code, modify the javascript and host the customized version on your own server. The tabbed layout in the Map Series app will allow you to change the text in the tab. It functions the exact same way as the bulleted layout except the tabs are not circles.
Nuts - I figured as much.
Thank you!
