This sample uses a helper method, added at v3.4, that defines a proxy for a set of resources. In this example all requests to route.arcgis.com are routed to the specified proxy url.esri.addProxyRule({ urlPrefix: "route.arcgis.com", proxyUrl: "/sproxy" });For demonstration purposes this sample uses a proxy that has been setup to use app logins and OAuth2 so you aren't required to log-in with an ArcGIS Online organizational subscription to run the sample.
<?xml version="1.0" encoding="utf-8" ?><ProxyConfig allowedReferers="*" mustMatch="false"> <serverUrls> <serverUrl url="http://gis.fwb.org/" matchAll="true"/> <serverUrl url="http://route.arcgis.com" clientId="pertinent ID is here" clientSecret="pertinent Secret is here" oauth2Endpoint="https://www.arcgis.com/sharing/oauth2/token" rateLimit=600 rateLimitPeriod=600 matchAll="true"> </serverUrl> <serverUrl url="http://services.arcgisonline.com" clientId="pertinent ID is here" clientSecret="pertinent Secret is here" oauth2Endpoint="https://www.arcgis.com/sharing/oauth2/token" rateLimit=600 rateLimitPeriod=600 matchAll="true"/> </serverUrls></ProxyConfig>
