When using the Compare Web Maps App in IE 10, the sync maps functionality doesn't work when panning. It works fine when you zoom in, zoom out, or double click on the map but not when panning around the map.It works fine in Chrome. Is this a bug or a limitation of IE 10?
Also, it would be nice to be able to set the sync options to be "on" by default for this app as well as having the side-by-side viewers default to the legend tab. Any chance those are enhancements that will be added at some point?
I'm also unable to change the title of this app from the default "Compare Web Maps" title. I've entered a custom title using both IE 10 and Chrome and neither attempt was successful in changing the title of the app. Is this a bug?
Looks like it is still not fixed, even in chrome, the two maps do not sync, either while panning or zooming in or out.
Here is my example:
http://utsa.maps.arcgis.com/apps/CompareAnalysis/index.html?appid=20bbff2f755f42cea354ff2912d372bb
Saloni,
I ran a quick test and the Sync button worked for me. By default it is not enabled so you'll have to click the sync button for the map you want to activate. Once active you should be able to pan/zoom the active map and have the other map stay in sync.
Kelly,
Thanks for the reply, Yes it works, but every time the application is opened or reloaded the user needs to click on that. I was working with Swipe Template earlier and it was enabled by default in that one.
Thanks.
