I have created a Tile Layer from a Tile Package (tpk) created from ArcMap 10.4.1.
The mxd from which the TPK was created from has a point layer with labels turned on.
These labels have a scale range which shows them only when zoomed out beyond 1:5000.
I can confinrm my labels appear only when zooming in more than 1:5000 in the mxd.
I cannot see them in AGOL however. I tried different ways of publishing the Tile Layer, but none solved the issue so far:
- creating the TPK using Share As->Tile Package and uploading through AGOL "Add Item from computer" and then publishing it as Tile Layer.
- creatig the TPK using "Manage Tile Cache" and "Export Tile Cache" and then the same as in previous point.
- setting the scale range to "same as layer" and setting the layer visibility to 1:5000
All I get is a Tile Layer with everything showing fine except I don't see any label at all.
I am on Italian language setting in my AGOL. Could this be the problem? I had another issue (not related to this one) which was caused by the Language setting.
Will try to change language and will come back to this if I resolve.
Thanks in advance for any help.
