I have a feature service that is hosted on ArcGIS.com, and the service contains a feature layer and a plain table. I want to update an attribute in the table from my Qt application, but I cannot. I do catch the signal onApplyFeatureEditsStatusChanged() and the status is indeed Enums.ApplyEditsStatusErrored, but I don't understand how to handle the actual error object: applyFeatureEditsErrors. That is, applyFeatureEditsErrors.error is undefined.
The things that I CAN do:
- query the table, and loop through the results logging all the attribute values,
- update attributes in the table using the REST interface in a browser.
To check my code, I used the feature layer endpoint instead, created a feature layer from it, and added it to the map:
GeodatabaseFeatureServiceTable {
url:someFeatureServiceRESTEndpointURL
onApplyFeatureEditsStatusChanged: {...}
}featureLayer.featureTable = myTableFromURL;
appMap.addLayer(featureLayer);
Then I waited for the FeatureLayer to initialize and verified that my table did too:
if (myTableFromURL.featureTableStatus === Enums.FeatureTableStatusInitialized) {
updatesEnabled = true;
}I can run a query to get features from the table/layer, and when the query is completed, loop through the records, updating data as I go:
thisRecord.setAttributeValue("SOME_ATTRIBUTE","SOME_NEW_VALUE");
myTableFromURL.updateFeature(thisRecord.uniqueId, thisRecord);And finally, once all the edits have been made to the features, tell the table to apply the changes:
myTableFromURL.applyFeatureEdits();
The edits are visible in the feature layer on arcgis.com.
Same process with the flat table (minus making and adding a feature layer to the map) does not work.
Is there a similar method to initialize a flat table (non-geo-enabled) as what happens when a feature layer is added to a map?
Thanks in advance,
Chris
