Before I go off spending hours on a possible wrong path I figured I would ask if anyone has ever seen an example of a newly created directions graphic being saved to a feature layer.
Thanks, Kelly! That did the trick. William, below is the code I was able to get working:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Directions Widget</title> <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css"> <style> html, body, #map { height:100%; width:100%; margin:0; padding:0; } body { background-color:#FFF; overflow:hidden; font-family:"Trebuchet MS"; } </style> <script src="http://js.arcgis.com/3.13/"></script> <script> var map; require([ "esri/urlUtils", "esri/map", "esri/dijit/Directions", "esri/layers/FeatureLayer", "dojo/parser", "dojo/on", "esri/graphic", "dojo/_base/array", "esri/config", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( urlUtils, Map, Directions, FeatureLayer, parser, on, Graphic, array, esriConfig ) { parser.parse(); esriConfig.defaults.io.proxyUrl = "http://server1/proxy/proxy.ashx" esriConfig.defaults.io.alwaysUseProxy = false; esriConfig.defaults.io.corsEnabledServers.push("server1"); urlUtils.addProxyRule({ urlPrefix: "route.arcgis.com", proxyUrl: "http://server1/proxy/proxy.ashx" }); urlUtils.addProxyRule({ urlPrefix: "traffic.arcgis.com", proxyUrl: "http://server1/proxy/proxy.ashx" }); map = new Map("map", { basemap: "streets", center:[-98.56,39.82], zoom: 4 }); var featureLayer = new FeatureLayer("http://server1/arcgis/rest/services/DirectionRoute/FeatureServer/0") var directions = new Directions({ map: map },"dir"); on(directions, "directions-finish", function(e){ var directions = e.result.routeResults[0].directions; directionFeatures = directions.features; array.forEach(directionFeatures, function(feature){ var graphic = new Graphic(feature.geometry, null, feature.attributes); featureLayer.applyEdits([graphic], null, null) }) }) directions.startup(); }); </script> </head> <body class="claro"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;"> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'" style="width:250px;"> <div id="dir"></div> </div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
Got the apply edits working in a test, still unsure of how the directions graphic layer is accessed.
Hi William,
I was able to get the direction features, but could not get the applyEdits method to work. Here is how I was able to obtain the features:
on(directions, "directions-finish", function(e){ var directions = e.result.routeResults[0].directions; directionFeatures = directions.features; array.forEach(directionFeatures, function(feature){ var graphic = new Graphic(feature.geometry, null, feature.attributes); console.log(graphic); featureLayer.applyEdits(graphic, null, null) }) })
Jake Skinner in your example if you add the graphics value you use in apply edits to an array it should work. For example:
featureLayer.applyEdits([graphic]);
