Dear all,I'm trying to convert dwg file into shp.The dwg file contains many layers containing different information regarding constrains.This data include text, lines and hatches (patterns)I tried to convert it to shp simply by right clicking on it and using export to shp conversion in ArcCatalog, it doesn't workThen I tried more sophisticated method by using Feature Class to Feature Class from ArcToolbox - still nothingAll I got was an empty output shpI also tried to export to geodatabase but that didn't work out either (although the process itself went fine,the output geodatabase was empty as well). I though hatches were the problem so I generated a boundary in AutoCad but that still did not work. I tried to copy boundaries to separate dwg (as polygons) and then convert the file but still nothing.Any idea why this is happening? All the layers are turned on, unfreezed and unlockedI'm using ArcInfo 10.1 and AutoCad 2014 (both trial versions)Please tell me why this is happening and how can I export dwg into shpRegards,Peter
