Juction on Complex Edge is not updated with FROM_EDGE_FIELD. ¿How cal i do it?
They should be, what does the log file say?
Hi Michael,
In Simplex Edge, the field is updated OK. In Complex Edge when a point element is inside a Complex Edge is not updated; but if the point element is at start or end is updated
Log File:
Edit Log Started at: 17/08/2017 11:26:24 AM-----------------------------------------AA - Removed the Feature Change event to run the manual rulesProcess Count: 0Unwiring the events#######################################################DERIVACION - ON_MANUALStarting AA***********************************************************############ 17/08/2017 11:28:03 AM ################
Setting sort order: Field - RUNORDER Querying table for Last Value for layer: DERIVACION Query Used: (TABLENAME = '*' OR TABLENAME = 'DERIVACION' OR TABLENAME like 'DERIVACION|*' OR TABLENAME like 'DERIVACION|%') AND VALUEMETHOD = 'Last_Value' Number of results: 0 Querying table for rules for layer: DERIVACION Query Used: (TABLENAME = '*' OR TABLENAME = 'DERIVACION' OR TABLENAME like 'DERIVACION|*' OR TABLENAME like 'DERIVACION|%') AND ON_MANUAL = 1 Number of results: 1 Looping through the rows ------------------------------------------------ Row Info Row Number 1 TableName: DERIVACION FieldName: CODIGOPADRE ValueInfo: CODIGOELEMENTO ValueMethod: FROM_EDGE_FIELD On Create: 0 On Change: 0
Checking for Subtype Restriction Field Name: CODIGOPADRE was found at index: 7 Trying: FROM_EDGE_FIELD Finished: FROM_EDGE_FIELD ------------------------------------------------DONE---------------------------------------#######################################################Wiring the eventsAA - Feature Change event readded after manual rulesAA - Removed the Feature Change event to run the manual rulesProcess Count: 0Unwiring the events#######################################################DYNAMICVALUE - ON_MANUALStarting AADynamic Value Table is the table that is edited, skippingDONE---------------------------------------#######################################################Wiring the eventsAA - Feature Change event readded after manual rulesAttribute Assistant is being suspendedAttribute Assistant is being turn offAttribute Assistant is being turn off**************************************Closing Log File 17/08/2017 11:28:31 AM
does AA requiere break lines at point features for use FROM_EDGE_FIELD?
If the point is not on the end or start, it will not work, regardless of line type. If the point is along the line, just use intersecting feature.
Why is it called "Edge" then? It's really misleading, maybe add this to the documentation that for a polyline "Edge" only works on Nodes. At the same time if you could define what a "Junction To" and "Junction From" are that would also be helpful, and they the Start Node and End Node respectively?
