Is it possible to change the mapView popup width in the 4.3 API?
This seems to have been updated in API 4.9:
<SPAN class="selector token">.esri-popup__main-container.esri-widget</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 310px <SPAN class="important token">!important</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="property token">max-height</SPAN><SPAN class="punctuation token">:</SPAN> 300px <SPAN class="important token">!important</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks - I had the esri-popup__main-container, but not the esri-view-width-<size>.
James,
Sure just do it with css:
<SPAN class="selector token">.esri-view-width-xlarge .esri-popup__main-container, .esri-view-width-large .esri-popup__main-container, .esri-view-width-medium .esri-popup__main-container</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 600px <SPAN class="important token">!important</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
