Open User Form Public Class TransLineEdit Inherits ESRI.ArcGIS.Desktop.AddIns.Button Dim pForm As New frmEdit Protected Overrides Sub OnClick() Try pForm.Show() Catch ex As Exception System.Windows.Forms.MessageBox.Show(ex.ToString, "OnClick") End Try End Sub End Class User Form Code: Imports ESRI.ArcGIS.ArcMapUI Imports ESRI.ArcGIS.Carto Imports ESRI.ArcGIS.Geodatabase Imports ESRI.ArcGIS.Geometry Imports ESRI.ArcGIS.ArcMap Imports ESRI.ArcGIS.DataManagementTools Imports ESRI.ArcGIS.Desktop Imports ESRI.ArcGIS.Editor Imports ESRI.ArcGIS.Framework Public Class frmEdit 'Declare variables that are used all thru the application Public pMxDoc As IMxDocument Public pMap As IMap Public pEditor As IEditor Public Application As IAppROT Private Sub UserForm_Initialize() 'Get Improvement Projects FeatureLayer Dim pFeatLyr As IFeatureLayer pFeatLyr = GetLayerByTOC("TransportationImprovementProjects_Lines") 'Get selected feature (only one) Dim pFeat As IFeature pFeat = GetSelFeat(pFeatLyr) 'Populate form controls with feature's attribute values txtPrjYear.Text = pFeat.Value(pFeat.Fields.FindField("YEAR")) txtPrjType.Text = pFeat.Value(pFeat.Fields.FindField("PROJECTYPE")) txtAgency.Text = pFeat.Value(pFeat.Fields.FindField("AGENCY")) txtLocation.Text = pFeat.Value(pFeat.Fields.FindField("LOCATION")) txtDescrip.Text = pFeat.Value(pFeat.Fields.FindField("DESCRIPTION")) txtCost.Text = pFeat.Value(pFeat.Fields.FindField("COST")) txtDate.Text = pFeat.Value(pFeat.Fields.FindField("DATEEDITED")) txtUser.Text = pFeat.Value(pFeat.Fields.FindField("USEREDITED")) Dim pDoc As IMxDocument pDoc = My.ArcMap.Document End Sub Private Sub cmdCancel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdCancel.Click End Sub Private Sub cmdUpdate_Click() On Error GoTo EH 'Initialize global variables Call Initialize() 'Get Transportation Improvement Projects FeatureLayer Dim pFeatLyr As IFeatureLayer pFeatLyr = GetLayerByTOC("TransportationImprovementProjects_Lines") 'Get Dataset from FeatureLayer Dim pEditDataset As IDataset pEditDataset = pFeatLyr 'If not editing, start editing dataset's Workspace If pEditor.EditState <> esriEditState.esriStateEditing Then pEditor.StartEditing(pEditDataset.Workspace) End If 'Get SelectionSet Dim pSelSet As ISelectionSet pSelSet = GetSelection(pFeatLyr) 'Get FeatureCursor from SelectionSet Dim pFCursor As IFeatureCursor pSelSet.Search(Nothing, True, pFCursor) 'Initialize first (only) feature Dim pFeat As IFeature pFeat = pFCursor.NextFeature 'Update attributes with user input pFeat.Value(pFeat.Fields.FindField("YEAR")) = txtPrjYear.Text pFeat.Value(pFeat.Fields.FindField("PROJECTYPE")) = txtPrjType.Text pFeat.Value(pFeat.Fields.FindField("LOCATION")) = txtLocation.Text pFeat.Value(pFeat.Fields.FindField("AGENCY")) = txtAgency.Text pFeat.Value(pFeat.Fields.FindField("DESCRIPTION")) = txtDescrip.Text pFeat.Value(pFeat.Fields.FindField("COST")) = txtCost.Text pFeat.Value(pFeat.Fields.FindField("DATEEDITED")) = txtDate.Text pFeat.Value(pFeat.Fields.FindField("USEREDITED")) = txtUser.Text 'Store changes to feature pFeat.Store() 'Stop editing and save edits pEditor.StopEditing(True) 'Refresh map pMxDoc.ActiveView.Refresh() 'Kill form Me.Close() 'Avoid error handler Exit Sub EH: 'Stop editing, trash edits If pEditor.EditState <> esriEditState.esriStateEditing Then pEditor.StopEditing(False) End If 'Display error MsgBox("A Runtime Error Occured. Error Number: " & CStr(Err.Number) & _ vbCrLf & "Error Description: " & Err.Description, vbExclamation + vbOKOnly) End Sub Private Sub cmdUpdate_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdUpdate.Click 'Kill form Me.Close() 'Clear selected features Dim pActiveView As IActiveView pActiveView = pMap pMap.ClearSelection() pActiveView.Refresh() End Sub Public Sub Initialize() 'Initalize global variables pMxDoc = Application.Document pMap = pMxDoc.FocusMap 'Instantiate the editor pEditor = Application.FindExtensionByName("ESRI Object Editor") End Sub Public Function GetLayerByTOC(ByVal lyrName As String) As IFeatureLayer 'This function finds a feature layer based on its TOC Name Call Initialize() Dim lyrCntr As Integer Dim pFeatLyr As IFeatureLayer For lyrCntr = 0 To pMap.LayerCount - 1 'Ensure that the layer is valid If pMap.Layer(lyrCntr).Valid = True Then 'Ensure that the layer is a feature layer If TypeOf pMap.Layer(lyrCntr) Is IFeatureLayer Then pFeatLyr = pMap.Layer(lyrCntr) If UCase(pMap.Layer(lyrCntr).Name) = UCase(lyrName) Then GetLayerByTOC = pFeatLyr Exit Function End If End If End If Next lyrCntr 'Layer not found. Show a message MsgBox("Layer " & lyrName & " not found !", vbCritical, "Error") End Function Public Function GetSelFeat(ByVal pFeatLyr As IFeatureLayer) As IFeature 'Gets selected feature from feature layer and returns feature 'Call this function only when you are sure that only one feature is selected 'Initialize the required variables Call Initialize() Dim pFeatSel As IFeatureSelection pFeatSel = pFeatLyr Dim pSelectionSet As ISelectionSet pSelectionSet = pFeatSel.SelectionSet Dim pFeatCur As IFeatureCursor pSelectionSet.Search(Nothing, True, pFeatCur) 'Return the selected feature GetSelFeat = pFeatCur.NextFeature End Function Public Function GetSelection(ByVal pFeatLyr As IFeatureLayer) As ISelectionSet 'Gets selection of feature layer and returns selection set 'Initialize the required variables Call Initialize() Dim pFeatSel As IFeatureSelection pFeatSel = pFeatLyr GetSelection = pFeatSel.SelectionSet End Function End Class
