I may not be using the correct term but what I would like to do is to add some text to the title bar or header are in WAB application based on the selection made in another widget.
How can I add some text dynamically to the title bar?
Mele,
The simplest way would be to manipulate the dom element directly:
Require: 'dojo/query'
var appTitleNode = query('.jimu-title.jimu-float-leading')[0]; var appTitle = appTitleNode.innerHTML; appTitleNode.innerHTML = appTitle + " my added string";
Hi Robert, I added 'dojo/query' to the end of this list which is at the beginning of a widgets Widget.js file (In your map progress widget). Is that all I need to do to "require" dojo/query?
Thanks!
define([ 'dojo/_base/declare', 'dojo/_base/lang', 'dojo/on', 'jimu/BaseWidget', 'esri/dijit/util/busyIndicator', 'jimu/utils', 'dijit/registry', 'dojo/dom-style', 'dojo/query' ],
Robert, this is perfect! Thanks for all your help!
Yes, Robert, that is what I was looking to do. Add some text dynamically to the Header Controller Widget below. I would like to add something at the end of 'Hydrant Maintenance Program'. It looks like this is the Title which is set in the config.json file.
Are you talking about the Header controller widget in the foldable theme?
