private var popWelcome:WelcomePopup = new WelcomePopup; protected function creationCompleteHandler(event:FlexEvent):void { PopUpManager.addPopUp(popWelcome, this, true, PopUpManagerChildList.POPUP); PopUpManager.centerPopUp(popWelcome); // more initialization code } // WelcomePopup.mxml code <?xml version="1.0" encoding="utf-8"?> <s:TitleWindow xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" title="About" close="closePopup();" width="500" height="500" cornerRadius="5"> <fx:Script> <=!=[=C=D=A=T=A=[ import mx.events.CloseEvent; import mx.managers.PopUpManager; protected function closePopup():void { PopUpManager.removePopUp(this); } protected function openNewBrowser(url:String):void { var urlRequest:URLRequest = new URLRequest(url); navigateToURL(urlRequest, "_blank"); } ]=]=> </fx:Script> <fx:Declarations> <!-- Place non-visual elements (e.g., services, value objects) here --> </fx:Declarations> <s:VGroup width="100%" height="100%" horizontalAlign="center"> <mx:Spacer height="10"/> <s:TabBar id="tabs" dataProvider="{vs}"/> <mx:ViewStack id="vs" width="100%" height="100%"> <s:NavigatorContent label="Welcome" width="100%" height="100%"> <s:VGroup width="100%" height="100%" horizontalAlign="center"> <s:TextArea id="ta1" width="80%" height="100%" textAlign="left" borderAlpha="0" paddingLeft="10" paddingRight="10" paddingTop="25" paddingBottom="10"> <s:textFlow> <s:TextFlow> <!--<s:p>Welcome to the Long Island Sound Benthic Mapping Project Spatial Prioritization Tool. As part of an ongoing effort to refine and implement a Benthic Habitat Mapping initiative for Long Island Sound, we are asking for your participation to help guide upcoming data collection. This portal contains a collection of existing data to assist you in determining whether an area is important and why, but should not be considered as the only factors for consideration. It is expected that you or your organization may have additional knowledge - this can and should be used in your evaluation as well. This portal, in conjunction with the PDF Prioritization Form, will be used to capture the information needs of your program and others to create a consensus of where future activities should be focused within the Sound.</s:p>--> <s:p> </s:p> <s:p>To turn on the individual data layers, click the arrow next to each thematic group to show the layers. Check the data layers to make them visible. You can also change the underlying map by clicking on one of the four options (OSM/Streets/Topo/Imagery) in the upper right corner.</s:p> <s:p> </s:p> <s:p>To identify the data for a given location, make sure the data layers are turned on, then click on the map. A results box will appear with each data themes listed in an individual data tab. Click a tab to reveal the information for your layer of choice.</s:p> <s:p> </s:p> <s:p>NOTE: The more layers you have turned on, the longer it will take to return the results, so you may need to be patient. </s:p> </s:TextFlow> </s:textFlow> </s:TextArea> </s:VGroup> </s:NavigatorContent> <s:NavigatorContent label="Contact" width="100%" height="100%"> <s:VGroup width="100%" height="100%" horizontalAlign="center" gap="-1"> <mx:Spacer height="10"/> <mx:Text text="For help or comments please contact:"/> <s:VGroup width="100%" height="20%" gap="-5" horizontalAlign="center"> <mx:Text text="Dan Dorfman"/> <mx:Text text="301-713-3028 x112"/> <mx:Text condenseWhite="true"> <mx:htmlText> <=!=[=C=D=A=T=A=[ <font color="0x0088d8"><u><a href='mailto:dan.dorfman@noaa.gov'>Dan.Dorfman@noaa.gov</a></u></font> ]=]=> </mx:htmlText> </mx:Text> </s:VGroup> <!--<mx:Image source="assets/deplogo1-99x100.gif" click="openNewBrowser('http://www.ct.gov/dep/site/default.asp');" buttonMode="true"/>--> <mx:Spacer height="20"/> <mx:Text condenseWhite="true" fontSize="12" fontWeight="bold"> <mx:htmlText> <=!=[=C=D=A=T=A=[ <a href='http://ccma.nos.noaa.gov/about/biogeography/' target='_blank'>NOAA's Biogeography Branch</a> ]=]=> </mx:htmlText> </mx:Text> <mx:Image source="assets/logo_100.gif" click="openNewBrowser('http://www.noaa.gov');" buttonMode="true"/> </s:VGroup> </s:NavigatorContent> </mx:ViewStack> <s:VGroup horizontalAlign="center"> <mx:Text condenseWhite="true"> <mx:htmlText> <=!=[=C=D=A=T=A=[ <font size="9"><p align="center"> <a href='http://www.commerce.gov/' target='_blank'>DOC</a> | <a href='http://www.noaa.gov/' target='_blank'>NOAA</a> | <a href='http://oceanservice.noaa.gov/' target='_blank'>NOS</a> | <a href='http://coastalscience.noaa.gov/' target='_blank'>NCCOS</a> | <a href='http://coastalscience.noaa.gov/notices/disclaimer.aspx' target='_blank'>Disclaimer</a> | <a href='http://oceanservice.noaa.gov/privacy.html' target='_blank'>Privacy Policy</a> <br> <a href='http://ccma.nos.noaa.gov//' target='_blank'>Web site owner: Center for Coastal Monitoring and Assessment</a> </p></font> ]=]=> </mx:htmlText> </mx:Text> </s:VGroup> <s:Button label="OK" click="closePopup();"/> <mx:Spacer height="10"/> </s:VGroup> </s:TitleWindow>
