Hi,I wanted to add the height information of two rasters and create another raster using the raster calculator. In Desktop Raster Calculator Tool the expression for the Same is like this - "Raster1" + "Raster2".I was trying to implement the same through coding in ArcGIS Engine using a Geoprocessing tool.The code snippet is as follows:Geoprocessor gp = new Geoprocessor(); gp.OverwriteOutput = true; RasterCalculator rasterCalc = new RasterCalculator(); rasterCalc.expression = " '@D:\NewFolder:\Raster1.tif" + "+" + "@D:\NewFolder:\Raster2.tif' "; rasterCalc.output_raster = "@D:\NewFolder:\Raster3.tif"; gp.Execute(rasterCalc,null);This is not getting executed and throws an error: HRESULT E_FAIL has been returned from a call to a COM component.
rasterCalc.expression = "D:\NewFolder\Raster1.tif" + " + " + "D:\NewFolder\Raster2.tif"; rasterCalc.output_raster = "D:\NewFolder\Raster3.tif";
Which version of ArcGIS?Just from a cursory look I'm wondering if your paths should be: rasterCalc.expression = "D:\NewFolder\Raster1.tif" + " + " + "D:\NewFolder\Raster2.tif"; rasterCalc.output_raster = "D:\NewFolder\Raster3.tif"; Your expression is simple enough you may want to use the Plus tool. That would likely avoid some complications from accessing this functionality from .NET.
I tried using the paths you have mentioned, but I got the same error again.
