# ---------------------------------------------------------------------------import sys, string, os, arcgisscriptingimport pyodbcgp = arcgisscripting.create()gp.CheckOutExtension("spatial")gp.AddToolbox("C:/Program Files (x86)/ArcGIS/ArcToolbox/Toolboxes/Spatial Analyst Tools.tbx")gp.AddToolbox("C:/Program Files (x86)/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx")# What features you want to tabulate FeaturesToTabulate = 'X:\\TableofFeatures.mdb\\FeatureTable' # Must be a valid classification table for this raster (all fields in the SQL statements need to be valid)Classification_Table = 'X:\\ClassificationTables\\SimpleClassTbl.dbf'Results_Geodatabase = 'U:\\CRUNCH\\TestTabProgram.mdb'Tabulated_Area_Table = "TblTestSimple"FieldtoTabulate = 'COUNT' #This the field that will be summarized TabulationMultiplier = 100 # This is a float(!) multiplier in case of a raster COUNT - * Cell size for exampleTabByZoneField = "True"Zone_field = 'WTRSHD_ID'WholeZoneName = 'WholeTable'# GUI entries (shortened for forum posting)FeatToTab = FeaturesToTabulateClassTbl = Classification_TableTabGeoDB = Results_GeodatabaseTabTbl = Tabulated_Area_TableFldtoTab = FieldtoTabulateTabMult = float(TabulationMultiplier)TabByZone = TabByZoneFieldZoneFld = Zone_fieldAltZone = WholeZoneName# Make new tabulated tablegeodbname = TabGeoDB.split("\\")[len(TabGeoDB.split("\\"))-1]geodbpath = TabGeoDB[:len(TabGeoDB)-len(geodbname)]if not(os.path.exists(TabGeoDB)): gp.CreatePersonalGDB_management(geodbpath, geodbname) try: gp.CreateTable(TabGeoDB,TabTbl)except: gp.AddMessage("Table already exists, please rename the output table or delete the existing table.") print "Output table already exists."gp.GetMessages()TabGeoDBTbl = TabGeoDB + "/" + TabTbl# Get ClassName and SQL Expression listsrows = gp.SearchCursor(ClassTbl,"","","","")row = rows.next()ClassNmList = [row.GetValue("ClassNm")]SQLExprList = [row.GetValue("SQLExpr")]row = rows.next()while row: theclass = row.GetValue("ClassNm") SQLexp = row.GetValue("SQLExpr") ClassNmList.append(theclass) SQLExprList.append(SQLexp) row = rows.next()del row, rows# Copy the attribute table or stand-alone table that is being tabulated into the Tabulation Geodatabase.fullname = gp.ParseTableName(os.path.basename(FeatToTab))nameList = fullname.split(",")FeatToTabTbl = nameList[2].split(".")[0].strip()#print FeatToTabTblif FldtoTab.lower() == "count": FldtoTab = "COUNT_"gp.OverwriteOutput = 1#May Need to make a table view for raster feature setslt = ["rasterdataset","rasterband"]try: dsc = gp.describe(FeatToTab) if string.lower(dsc.DatasetType) in lt: TblView = gp.MakeTableView_management(FeatToTab,FeatToTabTbl) gp.CopyRows_management(TblView, TabGeoDB + '\\' + FeatToTabTbl) else: TblView = TabGeoDB + '\\' + FeatToTabTbl gp.CopyRows_management(FeatToTab, TabGeoDB + '\\' + FeatToTabTbl) del dscexcept: gp.GetMessages()gp.OverwriteOutput = 0gp.GetMessages()gp.AddMessage("")try: if TabByZone == "True" or TabByZone == "true": # Get Zone List zrows = gp.SearchCursor(TblView,"","","",str(ZoneFld) + " A") zrow = zrows.next() zonelast = zrow.GetValue(ZoneFld) ZoneList = [zonelast] zrow = zrows.next() maxlen = len(zonelast) while zrow: zone = zrow.GetValue(ZoneFld) if zone == zonelast: zrow = zrows.next() else: ZoneList.append(zone) zonelast = zone zrow = zrows.next() if len(zone)>maxlen: maxlen = len(zone) del zrow, zrows fields = gp.ListFields(TblView) field = fields.next() while field: if field.Name == ZoneFld: zonefldtype = field.Type break field = fields.next() # Begin the tabulation file with a zone ID and remove the auto-generated "Field1" try: if zonefldtype == "String": gp.AddField_management(TabGeoDBTbl,"ZoneID","Text",maxlen+4) else: gp.AddField_management(TabGeoDBTbl,"ZoneID",zonefldtype) gp.DeleteField_management(TabGeoDBTbl,"Field1") gp.AddField_management(TabGeoDBTbl,"TOTTABAREA","Long") except: gp.GetMessages() # Add field for Class Name in the Classification Table for theclass in ClassNmList: try: gp.AddField_management(TabGeoDBTbl,theclass,"Long") except: gp.GetMessages() #Try-Except for debug, if already added # Open the ODBC Connection to the Personal Geodatabase try: DBfile = TabGeoDB #'/data/MSAccess/Music_Library.mdb' conn = pyodbc.connect('DRIVER={Microsoft Access Driver (*.mdb)};DBQ='+DBfile) cursor = conn.cursor() gp.AddMessage("Connection opened") except: print gp.GetMessages() gp.AddMessage("Problem Occurred with the ODBC connection.") del gp exit i = 0 classedtotarea = 0 # Begin the tabulation table by inserting the ZoneID's SQL = "SELECT * FROM " + TabTbl tblcnt = cursor.execute(SQL).rowcount if tblcnt >0: print "Tab Table already populated with zones." else: SQL = "INSERT INTO " + TabTbl + " ( ZoneID ) " \ "SELECT " + FeatToTabTbl + "." + ZoneFld + " " \ "FROM " + FeatToTabTbl + " " \ "GROUP BY " + FeatToTabTbl + "." + ZoneFld + " " \ "ORDER BY " + FeatToTabTbl + "." + ZoneFld + ";" cursor.execute(SQL) conn.commit() gp.AddMessage("Select Zones into Tab Table Complete.\n") # Process the features to tabulate, looping through each Class/SQL Expression for zone in ZoneList: print "Working on zone: " + str(zone) gp.AddMessage("Working on zone: " + str(zone)) if zonefldtype == "String": zone = "'" + zone + "'" #Get the total area for the zone whereclause = ZoneFld + ' = ' + zone totSQL = "SELECT Sum(" + FldtoTab + ") as TOTCOUNT " + \ "FROM " + FeatToTabTbl + " " + \ "WHERE " + whereclause + ";" print totSQL gp.AddMessage(str(totSQL)) tottabarea = cursor.execute(totSQL).fetchone()[0] if tottabarea is None: tottabarea = 0 else: tottabarea = tottabarea * TabMult insertSQL = "UPDATE " + TabTbl + " " + \ "SET TOTTABAREA =" + str(tottabarea) + " " + \ "WHERE ZoneID = " + zone + ";" cursor.execute(insertSQL) conn.commit() i = 0 for theclass in ClassNmList: SQL = SQLExprList i = i+1 #Create the summary by this class whereclause = "(" + SQL.replace('"','') + ") AND " + ZoneFld + ' = ' + zone totSQL = "SELECT Sum(" + FldtoTab + ") as TOTCOUNT " + \ "FROM " + FeatToTabTbl + " " + \ "WHERE " + whereclause + ";" gp.AddMessage(str(totSQL)) totarea = cursor.execute(totSQL).fetchone()[0] gp.AddMessage("Class area is = " + str(totarea)) if totarea is None: totarea = 0 else: totarea = totarea * TabMult #Add the insert SQL to put the results into the Tabulation Table insertSQL = "UPDATE " + TabTbl + " " + \ "SET " + theclass + "=" + str(totarea) + " " + \ "WHERE ZoneID = " + zone + ";" cursor.execute(insertSQL) conn.commit() gp.AddMessage("Class complete\n") gp.AddMessage("Completed tabulation table.")except: gp.GetMessages() try: cursor.close() conn.close() del conn, cursorexcept: passdel gp
@IDENTITY") f=cursor.fetchone() cursor.close() conn.commit() arcpy.AddMessage("DONE") except Exception,e: arcpy.AddMessage("e="+str(e)) finally: conn.close()
Results: out: echo:test Messages: esriJobMessageTypeInformative: Executing (InputScriptLabel): InputScript test esriJobMessageTypeInformative: Start Time: Tue Mar 27 11:27:04 2012 esriJobMessageTypeInformative: Running script InputScript... esriJobMessageTypeInformative: START esriJobMessageTypeInformative: DONE esriJobMessageTypeInformative: Completed script InputScript... esriJobMessageTypeInformative: Succeeded at Tue Mar 27 11:27:04 2012 (Elapsed Time: 0.00 seconds)
Results: out: echo:test Messages: esriJobMessageTypeInformative: Executing (InputScriptLabel): InputScript test esriJobMessageTypeInformative: Start Time: Tue Mar 27 11:23:31 2012 esriJobMessageTypeInformative: Running script InputScript... esriJobMessageTypeInformative: START esriJobMessageTypeInformative: e='NoneType' object is not callable esriJobMessageTypeInformative: Completed script InputScript... esriJobMessageTypeInformative: Succeeded at Tue Mar 27 11:23:31 2012 (Elapsed Time: 0.00 seconds)
if __name__ == '__main__': import os, sys e = sys.executable.lower() if 'arcmap.exe' in e or 'arccatalog.exe' in e: import pyodbc main()
mahunter243pyodbc and ArcGIS do not play well together. I get the same problem described here, run once ok, then crash on the 2nd run. There are 2 workarounds that I've found. 1st, run the geoprocessing tool out of process. I don't like this option, since it slows things down considerably. 2nd is simply to import pyodbc into the Python window global namespace when you start Arcmap or ArcCatalog. For some reason when that's done, any tool using pyodbc will run as many times as needed. You can do this automatically when arcmap or arccatalog starts (if it starts with the Python window open) by setting the PYTHONSTARTUP environment variable to a startup script. Here's the pertinent part of my startup script: if __name__ == '__main__': import os, sys e = sys.executable.lower() if 'arcmap.exe' in e or 'arccatalog.exe' in e: import pyodbc main()
I�??ve been struggling with the same issue. I have not been able to make my script run properly when deploying them as geoprocessing services using the pyodbc module. To me it seems like installing PyWin32 and using the odbc module is a better approach. Pyodbc and odbc is very alike,
import arcpy, pyodbc conn = pyodbc.connect('DSN=<DSN_name>;PWD=<Password>') conn.autocommit = True cursor = conn.cursor() cursor.execute('SET CHAINED OFF') cursor.execute('{call Sybase_Stored_proc()}') rows = cursor.fetchall() arcpy.AddMessage(len(rows)) cursor.close() conn.close() del rows, cursor, conn
Thanks for the tip on the pypyodbc. Who would have guessed the pyodbc wouldn't work even for a simple select statement.
I have used the pypyodbc for one project and it seems to be ok.
Next project - script works fine as a python script. Works fine as a custom ArcTool pointing to the script. Turn it into a geoprocessing service and it fails at the cursor.execute line.
Hi, we had a similar issue when running a python toolbox tool in ArcMap that used pyodbc to run a stored procedure on Sql Server then present the results into ArcMap. What was happening was ArcMap was holding open the sql processes that the stored procs ran on which created schema locks and stopped the tool running subsequent times in the same ArcMap session (the tool would just hang because of the schema lock).The fix for us was to type RETURN 0 at the end of our stored proc which I guess tells ArcMap that the stored proc has completed and the process can be closed.If you are not running stored procs then the pyodbc documentation suggests closing your connection and deleting the variable.for example
>> cnxn = pyodbc.connect('DRIVER={SQL Server};SERVER=localhost;DATABASE=testdb;UID=me;PWD=pass')
>> # Run your sql query
>> cnxn.close()
>> del cnxn
I had many of the symptoms as described above on 10.3 - in particular every 2nd GPService exec would crash.
I resolved this issue by switching from pyodbc to pypyodbc (i.e. a pure python implementation pypyodbc - A Pure Python ODBC Library based on ctypes - Google Project Hosting ). Note that there are differences between these implementations. Good luck.
I ran into this issue as well with pyodbc when running a tool script within a "CURRENT" map document. The tool script would work fine the first time but any additional attempt to run would cause ArcMap to hang and crash. I made sure to close the cursor and connection but it didn't make a difference.
In my case I only had to change two minimal lines of code to go with pypyodbc instead. All I had to change was the module import to pypyodbc and then the connect method from pyodbc.connect() to pypyodbc.connect(). The cursor, execute, and fetchall methods are the same.
I was experiencing almost the exact same situation as Detaille Octave. A GP task that ran successfully the first time and then failed on subsequent runs. Switching to `pypyodbc` fixed the issue for me. THANKS!
