When I hover over a point on the map it is highlighted in the datagrid, but when I hoverover a point in the datagrid it does not highlight the point on the map. I believe something is wrong with my findGraphicByAttribute function, I have tried changing the if statement around but to no avail. Any suggestions?Thanks.This code was taken from the following site and modified.http://blogs.esri.com/Dev/blogs/arcgisserver/archive/2009/02/19/Sychronizing-map-and-datagrid-interaction-with-the-ArcGIS-API-for-Flex.aspxvar results:ArrayCollection = new ArrayCollection;
function onResult(featureSet:FeatureSet, token:Object = null):void
if (featureSet.features.length > 0)
for each (var myGraphic3:Graphic in featureSet.features)
//Adds a mouseover event for the graphic
myGraphic3.addEventListener( MouseEvent.MOUSE_OVER, onMouseOver );
myGraphic3.addEventListener( MouseEvent.MOUSE_OUT, onMouseOut );
myGraphic3.symbol = resultsSymbol;
myGraphicsLayer.add(myGraphic3);
results.addItem(myGraphic3.attributes);
map.addLayer(myGraphicsLayer);
dg.visible = true;
dg.dataProvider = results;
function onMouseOver( event : MouseEvent ) : void
var graphic : Graphic = Graphic( event.target );
graphic.symbol = highlightSymbol;
for each( var attributes : Object in dg.dataProvider )
if (attributes === graphic.attributes)
dg.selectedIndex = (dg.dataProvider as ArrayCollection).getItemIndex(attributes)
dg.scrollToIndex(dg.selectedIndex);
function onMouseOut( event : MouseEvent ) : void
Graphic( event.target ).symbol = resultsSymbol;
dg.selectedIndex = -1;
function onItemRollOver( event : ListEvent ) : void
findGraphicByAttribute(event.itemRenderer.data).symbol = highlightSymbol;
function onItemRollOut( event : ListEvent ) : void
findGraphicByAttribute(event.itemRenderer.data).symbol = resultsSymbol;
function findGraphicByAttribute( attributes : Object ) : Graphic
for each (var graphic:Graphic in myGraphicsLayer.graphicProvider)
if (graphic.attributes == attributes)
return graphic;
return null;
