private function onQueryExecuteComplete(event:QueryEvent):void { var fset:FeatureSet = event.featureSet; if(district1tool == true) { for each(var graphic:Graphic in fset.features) { graphic.name = graphic.attributes.PRECINCT for each(var graLyrGraphic:Graphic in myGraphicsLayer.graphicProvider) { if(graLyrGraphic.name == graphic.name) { for (var i:int = myGraphicsLayer.numGraphics - 1; i >= 0; i--) { if(myGraphicsLayer.graphicProvider.name == graphic.name) { if (district1tool == true) { dist1PopTotal -= myGraphicsLayer.graphicProvider.attributes.POPULATION myGraphicsLayer.remove(myGraphicsLayer.graphicProvider); return; } } } return; } } graphic.symbol = new SimpleFillSymbol('solid',0xcc0000,.7) myGraphicsLayer.add(graphic); dist1PopTotal+=graphic.attributes.POPULATION; } return; }
private function onQueryExecuteComplete(event:QueryEvent):void { var oneGraphic:Graphic = event.target as Graphic; var fset:FeatureSet = event.featureSet; for each (var graphic:Graphic in fset.features) { for each(var graLyrGraphic:Graphic in myGraphicsLayer.graphicProvider) { myInfo.text = "started loop"; if (graLyrGraphic.attributes === graphic.attributes) { myInfo.text = "found similar geometry"; //THIS IS WHERE I WOULD REMOVE THE GRAPHIC return; } } graphic.symbol = new SimpleFillSymbol('solid',0xcc0000,.7) myGraphicsLayer.add(graphic); dist1PopTotal+=graphic.attributes.POPULATION; } return; }
