I want to strip off the last 4 characters of a layer name that is in my mxd. It is the only layer. It is a MrSid file. I want to export this image to pdf using the layer name without the .sid part. This code exports the map to PDF but it is not stripping off the .sid part. Ex: J-228-01-W-2013.sid.pdfI used 4 as the number of characters to strip off because I assumed that the dot needs to be removed also.import arcpy,os
mxd = arcpy.mapping.MapDocument(r"C:\GIS\designsheet.mxd")
df = arcpy.mapping.ListDataFrames(mxd)[0]
df.rotation = 0
lname = arcpy.mapping.ListLayers(mxd)[0].name
outFile = r"C:\GIS\output\\" + lname.rstrip('4') + ".pdf"
arcpy.mapping.ExportToPDF(mxd, outFile)
- Mike
