Ah yes, one of those new 10.1 arcpy.da features I was referring to. However, I need a v.10 solution. 😛But your idea is a good one. Regards
Thanks for the replies. I'm aware of the options you have suggested but I really need to invoke a function because one of the parameters needs to be a clob. I could use the cx_Oracle module but then I get back a non-ESRI cursor that I then have to convert. Ordinarily not a big deal but I have to do this a lot on a lot of data and in the interest of performance and maintenance. I see v.10.1 has expanded the arcpy.da module with functionality that may do the trick.
Does the ArcSDESQLExecute class support calling Oracle functions? If yes, does it further support the return of a ref_cursor? I've tried sql = "call BlahFunction()"sdeReturn = conn.execute(sql)Regards
