I have been experiencing problems with the grid theme on a multi page survey with multiple groups. 95 % of the time the grids works fine with different columns, but then I get cases that the number of columns gets all wacky and does not follow the design.
Is there a way to see how the number of columns are configured and correct the error, because shifting the fields around or playing with the number of columns is very time consuming.
In the example attached you can see the group appearance is set to "w4 field-list" (Activate the last page by selecting RMU yes on Page 3)
Line 107 appearance is set to "w2 minimal" but in the servey it appears as "w3"? (Last page on survey)
This is not the first time I am experiencing this problem, I have previously just worked around the errors. I need to compile over a 100 equipment related surveys and this is a real concern. (Is there some rules that I am missing for using Grid Theme?)
Any assistance will be appreciated.
George
