<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Simple Map</title> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } body { background-color: #FFF; overflow: hidden; font-family: "Trebuchet MS"; } </style> <script>dojoConfig = {async: true, parseOnLoad: true}</script> <script src="http://js.arcgis.com/3.8/"></script> <script> var map, dialog; require([ "dojo/dom-construct", "dojo/on", "dojo/dom", "esri/map", "esri/layers/FeatureLayer", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/renderers/SimpleRenderer", "esri/graphic", "esri/lang", "dojo/_base/Color", "dojo/number", "dojo/dom-style", "dijit/TooltipDialog", "dijit/popup", "dojo/domReady!" ], function( domConstruct, on, dom, Map, FeatureLayer, SimpleFillSymbol, SimpleLineSymbol, SimpleRenderer, Graphic, esriLang, Color, number, domStyle, TooltipDialog, dijitPopup ) { map = new Map("map", { basemap: "streets", center: [-80.94, 33.646], zoom: 8, slider: false }); window.myMap = map; var southCarolinaCounties = new FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/3", { mode: FeatureLayer.MODE_SNAPSHOT, outFields: ["NAME", "POP2000", "POP2007", "POP00_SQMI", "POP07_SQMI"] }); southCarolinaCounties.setDefinitionExpression("STATE_NAME = 'South Carolina'"); var symbol = new SimpleFillSymbol( SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([255,255,255,0.35]), 1 ), new Color([125,125,125,0.35]) ); southCarolinaCounties.setRenderer(new SimpleRenderer(symbol)); map.addLayer(southCarolinaCounties); map.infoWindow.resize(245,125); dialog = new TooltipDialog({ id: "tooltipDialog", style: "position: absolute; width: 250px; font: normal normal normal 10pt Helvetica;z-index:100" }); dialog.startup(); var highlightSymbol = new SimpleFillSymbol( SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([255,0,0]), 3 ), new Color([125,125,125,0.35]) ); //close the dialog when the mouse leaves the highlight graphic map.on("load", function(){ map.graphics.enableMouseEvents(); map.graphics.on("mouse-out", closeDialog); }); //listen for when the onMouseOver event fires on the countiesGraphicsLayer //when fired, create a new graphic with the geometry from the event.graphic and add it to the maps graphics layer southCarolinaCounties.on("mouse-over", function(evt){ var t = "<b>${NAME}</b><hr><b>2000 Population: </b>${POP2000:NumberFormat}<br>" + "<b>2000 Population per Sq. Mi.: </b>${POP00_SQMI:NumberFormat}<br>" + "<b>2007 Population: </b>${POP2007:NumberFormat}<br>" + "<b>2007 Population per Sq. Mi.: </b>${POP07_SQMI:NumberFormat}"; var content = esriLang.substitute(evt.graphic.attributes,t); var highlightGraphic = new Graphic(evt.graphic.geometry,highlightSymbol); map.graphics.add(highlightGraphic); dialog.setContent(content); domStyle.set(dialog.domNode, "opacity", 0.85); dijitPopup.open({ popup: dialog, x: evt.pageX, y: evt.pageY }); }); function closeDialog() { map.graphics.clear(); dijitPopup.close(dialog); } on(dom.byId("hideMapBtn"), "click", function(){ console.log("HIDE"); window.myMap.container.style.display="none"; var mapNode = dojo.byId("map"); domConstruct.place(mapNode,dojo.byId('hidecontent'),"last"); var contentPane =dijit.registry.byId("mapdiv"); contentPane.setHref("load.html"); }); on(dom.byId("showMapBtn"), "click", function(){ console.log("SHOW"); if(window.myMap.container.style.display == "none"){ var contentPane =dijit.registry.byId("mapdiv"); contentPane.setHref("mapcontainer.html"); contentPane.set("onDownloadEnd",function(){ var mapNode = dojo.byId("map"); domConstruct.place(mapNode,dojo.byId('mapcontainer'),"last"); window.myMap.container.style.display="block"; }); } }); }); </script> </head> <body class="claro"> <div id="hidecontent"></div> <div id="mapdiv" data-dojo-type="dijit/layout/ContentPane" > <div id="map"></div> </div> <input id="hideMapBtn" type='submit'> <input id="showMapBtn" type='submit' value='show'> </body> </html>
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Simple Map</title> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } body { background-color: #FFF; overflow: hidden; font-family: "Trebuchet MS"; } </style> <script>dojoConfig = {async: true, parseOnLoad: true}</script> <script src="http://js.arcgis.com/3.8/"></script> <script> var map, dialog; require([ "esri/map", "esri/layers/FeatureLayer", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/renderers/SimpleRenderer", "esri/graphic", "esri/lang", "dojo/_base/Color", "dojo/number", "dojo/dom-style", "dijit/TooltipDialog", "dijit/popup", "dojo/domReady!" ], function( Map, FeatureLayer, SimpleFillSymbol, SimpleLineSymbol, SimpleRenderer, Graphic, esriLang, Color, number, domStyle, TooltipDialog, dijitPopup ) { map = new Map("map", { basemap: "streets", center: [-80.94, 33.646], zoom: 8, slider: false }); var southCarolinaCounties = new FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/3", { mode: FeatureLayer.MODE_SNAPSHOT, outFields: ["NAME", "POP2000", "POP2007", "POP00_SQMI", "POP07_SQMI"] }); southCarolinaCounties.setDefinitionExpression("STATE_NAME = 'South Carolina'"); var symbol = new SimpleFillSymbol( SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([255,255,255,0.35]), 1 ), new Color([125,125,125,0.35]) ); southCarolinaCounties.setRenderer(new SimpleRenderer(symbol)); map.addLayer(southCarolinaCounties); map.infoWindow.resize(245,125); dialog = new TooltipDialog({ id: "tooltipDialog", style: "position: absolute; width: 250px; font: normal normal normal 10pt Helvetica;z-index:100" }); dialog.startup(); var highlightSymbol = new SimpleFillSymbol( SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([255,0,0]), 3 ), new Color([125,125,125,0.35]) ); //close the dialog when the mouse leaves the highlight graphic map.on("load", function(){ map.graphics.enableMouseEvents(); map.graphics.on("mouse-out", closeDialog); }); //listen for when the onMouseOver event fires on the countiesGraphicsLayer //when fired, create a new graphic with the geometry from the event.graphic and add it to the maps graphics layer southCarolinaCounties.on("mouse-over", function(evt){ var t = "<b>${NAME}</b><hr><b>2000 Population: </b>${POP2000:NumberFormat}<br>" + "<b>2000 Population per Sq. Mi.: </b>${POP00_SQMI:NumberFormat}<br>" + "<b>2007 Population: </b>${POP2007:NumberFormat}<br>" + "<b>2007 Population per Sq. Mi.: </b>${POP07_SQMI:NumberFormat}"; var content = esriLang.substitute(evt.graphic.attributes,t); var highlightGraphic = new Graphic(evt.graphic.geometry,highlightSymbol); map.graphics.add(highlightGraphic); dialog.setContent(content); domStyle.set(dialog.domNode, "opacity", 0.85); dijitPopup.open({ popup: dialog, x: evt.pageX, y: evt.pageY }); }); function closeDialog() { map.graphics.clear(); dijitPopup.close(dialog); } }); function showMap(){ require(["dijit/layout/ContentPane","dojo/dom-construct"],function(layout,domConstruct){ var contentPane =dijit.registry.byId("mapdiv"); console.log(" contentPane"+contentPane); contentPane.setHref("mapcontainer.html"); contentPane.set("onDownloadEnd",function(){ var mapNode = dojo.byId("map"); dojo.byId("map").style.display="block"; domConstruct.place(mapNode,dojo.byId('mapcontainer'),"last"); }); }); } function hideMap(){ var mapNode = dojo.byId("map"); dojo.byId("map").style.display="none"; require(["dijit/layout/ContentPane","dojo/dom-construct"],function(layout,domConstruct){ domConstruct.place(mapNode,dojo.byId('hidecontent'),"last"); dojo.byId("map").style.display="none"; var contentPane =dijit.registry.byId("mapdiv"); console.log(" contentPane"+contentPane); contentPane.setHref("load.html"); }); } </script> </head> <body class="claro"> <div id="hidecontent"></div> <div id="mapdiv" data-dojo-type="dijit/layout/ContentPane" > <div id="map"></div> </div> <input type='submit' onclick='hideMap();'> <input type='submit' value='show' onclick='showMap();'> </body> </html>
<div id="mapcontainer"> </div>
<div id="temp"> </div>
