Good morning,
We are beginning to work out using Attribute Assistant in 10.2/10.3 and have been having some issues. Hopefully there are others that have solved these and can provide some input on how to clear things up a bit. I know there are a lot of users that really have had success using the Attribute Assistant.
The {Option} portion of the Generate_ID method does not seem to be working...
My table uses the Generate_ID for generating a FacilityID for the LGIM so my tables and fields look like the following:
GenerateID Table
| OBJECTID | Sequence Name | Sequence Counter | Interval Value
| Comments |
| 1 | FACGENID | 1 | 1 | Generates a Facility ID number incrementing at 1 |
DynamicValue Table
| OBJECTID | Table Name | Field Name | Value Method | Value Info | On Create | On Change (Attribute) | On Change (Geometry) | Manual Only | Rule Weight | Comments |
| 1 | FacilitySitePoint | FacilityID | Generate_ID | FACGENID|6|[seq] | True | False | False | False | 1 | |
This method does work and will successfully generate an ID value but also regenerates if a user mistakenly selects a feature that already has an ID.
If I use the option and input the Value Info field as FACGENID|6|[seq]|True and the values in the table are <Null> the Attribute Assistant does not generate a value. If I change the field to FACGENID|6|[seq]|False, it also does not generate a value. I have purposefully left out the additional ID information for simplicity to test the generation of values using this tool.
I did have to import and modify the two tables from the Address Data Management template as I was missing the domains from the tables when I pulled them in empty from the Attribute Assistant download.
One thing we have been looking at is if we can add the Generate_ID command into an Expression method. Does anyone know if this is possible? The reason being we are trying to keep a portion of our primary keys smart in that it collects the value from the SUBTYPEFIELD for the facilities and populates those down. It will also give us a basis to move expressions across into some of our other features like RoadCenterline and AddressPoint.
Justin West
