I have related tables working in AGO. Which is pretty neat. See this link on how to do it:
http://doc.arcgis.com/en/arcgis-online/create-maps/configure-pop-ups.htm#ESRI_SECTION1_09B2E0D22072457AAC8D025377DD7CF9
Once this functionality has been created in an AGO map can it be used in the out of the box WAB?? It doesn't appear like it when I load my AGO map into the WAB. Anyone have any thoughts on this?
Thanks for your input!
Hi Frank,
Did you ever discover anything more with this related tables issue?
I really want to try the WAB Chart widget, but I cannot seem to access the related data like you can in a map on AGOL?
Thanks,Warren
I was told by Esri yesterday that this functionality is added in the next version of the WAB to be released any day now. As of today it has not been released so I can not verify it.
Thanks Robert, I wasn't even aware that a new version was close.
W.
This functionality was released this week, so you should be able to view related tables using WAB right now. It's working for me both in the pop-up and in the table.
ArcGIS Online | What's New - March 2015
Ryan,
True it is released for AGOL users but the Web AppBuilder Developer version is not yet released with this update and Portal users are still behind by two versions now.
Oh, gotcha. Thanks for the clarification.
Related tables are now supported in the WAB 'out-of-the-box' as of the release a couple of days ago. I've tried it and it works. Basically you can go only one level deep into related tables, and these are view only. Editing of the related tables is not currently supported. Also, you can not use the related tables to build queries.
And where would one find this download released a couple days ago?
Warren
Warren,
Go to ArcGIS Online and create a new Web AppBuilder app. Of course, the Web Map must use a geodatabase with related tables.
Brenda
Ah yes, as Robert said above, it is 'partially' working on AGOL, but I'm looking for the functionality without AGOL, with the WAB developer version. I said 'partially' because related tables are still not working for Charts in WAB on AGOL. Yes, I can view the related records in the attribute table, but the related table is still not available when trying to add a chart
