var link = domConstruct.create("a", { "class": "action", "id": "statsLink", "innerHTML": "Attach Documents", //text that appears in the popup for the link "href": "javascript: void(0);" }, query(".actionList", map.infoWindow.domNode)[0]);
//when the link is clicked register a function that will run on(link, "click", showDialog); },
but doesn't work,
I'm using Editor Widget as in this sample (Edit rivers and waterbodies ) I'm wondering if is it possible to add the link as I want ?
thanks in advance !
Dairis,
Here is how you would do that for the edit widgets attributes inspector:
<SPAN class="keyword token">var</SPAN> link <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"a"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"class"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"atiNavButtons"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"id"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"statsLink"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"innerHTML"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Attach Documents"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">//text that appears in the popup for the link</SPAN> <SPAN class="string token">"href"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"javascript: void(0);"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token function">query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".atiButtons"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//when the link is clicked register a function that will run</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>link<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> showDialog<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thank you so much !
