Hi I dynamically create a listview based on data from SQL server, which lists maps layers and visibility. I can loop through list to create array or visible layers. This works great when I make a change in the listview but I would like to use the process to setVisibleLayers when the map is loaded. I am trying to set the setVisibleLayers method of layer to the same .get function I use elsewhere but the layers are not visible. I believe it is because listview has not been fully created yet. Is there a way I can set the visible layers this way?
var roadLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gisappserv3.spokanecounty.org/ArcGIS/rest/services/Engineering/ENGINEERINGqueries_10/MapServer",
{ id: "roadLayer",
visible: true });
roadLayer.setVisibleLayers([$('#ulLayerVisibility input[type="checkbox"]:checked').map(function () {
var checkid = $(this).attr('id').split(":");
return checkid[1];
}).get()]);
map = new Map("map", {
extent: customExtentAndSR
map.addLayers([roadLayer]);
