Anyone still having problems with this in VB.Net? I ran on to the same problem with version 1.4 as well as 1.5. I wrote a C# DLL with some "Get Geometry" functions to deal with all the buffer types. One point to note is that when the new geometry is returned, it still shows as a ShapeBuffer in debugging, but you can still access the PointShapeBuffer, MultiPointShapeBuffer, MultiPartShapeBuffer, MultiPatchShapeBuffer properties regardless. I hope this helps someone:
Usage:
Imports ESRIFileGDB.ConvertShapeBuffer
Dim geometry As New PointShapeBuffer = GetPointGeometry(row)
ESRIFileGDB.cs
using System;using System.Collections.Generic;using System.Linq;using System.Text;using System.Threading.Tasks;using Esri.FileGDB;
namespace ESRIFileGDB{ public class ConvertShapeBuffer {
public ConvertShapeBuffer() { }
public static PointShapeBuffer GetPointGeometry(ref Esri.FileGDB.Row shapeRow) { try { PointShapeBuffer pointGeometry = shapeRow.GetGeometry(); return pointGeometry; } catch { return null; } }
public static MultiPointShapeBuffer GetMultiPointGeometry(ref Esri.FileGDB.Row shapeRow) { try { MultiPointShapeBuffer multipointGeometry = shapeRow.GetGeometry(); return multipointGeometry; } catch { return null; } }
public static MultiPatchShapeBuffer GetMultiPatchGeometry(ref Esri.FileGDB.Row shapeRow) { try { MultiPatchShapeBuffer patchGeometry = shapeRow.GetGeometry(); return patchGeometry; } catch { return null; } }
public static MultiPartShapeBuffer GetMultiPartGeometry(ref Esri.FileGDB.Row shapeRow) { try { MultiPartShapeBuffer multipartGeometry = shapeRow.GetGeometry(); return multipartGeometry; } catch { return null; } } }}
I have been playing with the API in VB.net and can not get a geometry from the GetGeometry() function.According to the C# examples:PointShapeBuffer pointGeometry = row.GetGeometry(); point = pointGeometry.point;In Vb.net the GetGeometry function explicity states it returns a ShapeBuffer. It will not accept a CType converstion to PointShapeBuffer, and will not accept a PointShapeBuffer as an output. The Help states the Geometry function returns a ShapeBuffer so I do not understand how to get a point from (Get)Geometry function.Any advice would be appreciated. David
