IIS on both with windows authentication. The error is only every now and then, and I haven't been able to figure what is causing it. I never got it before 2.4. Thanks for the help.Matt
Just checking as you say you have two servers - IIS settings were applied to both?
We have had this problem ourselves. It ended up being an issue with the map services, not the Flex viewer. Initially it happened when the rest cache wasn't cleared after a change to the services, meaning that the Flex Viewer was attempting to retrieve fields that were now hidden.This happened in another instance relating to changes in the map services but I can't recall what was changed. I can investigate with the team and get back to you. Hopefully that'll give you a starting point at least, knowing that we did resolve the problem here
Did you try loading mapserver URL from internet explorer?
