i need to do something when map is zoomed to a scale. i need to know the mapscale in real-time when the map is being zoomed.
Assuming you have a reference to the AGSMapView named mapView, then if you're using Runtime 100.x, you can use KVO on the map's mapScale property, like this:
<SPAN class="keyword token">override</SPAN> func <SPAN class="token function">viewDidLoad</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> super<SPAN class="punctuation token">.</SPAN><SPAN class="token function">viewDidLoad</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> mapView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addObserver</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">,</SPAN> forKeyPath<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"mapScale"</SPAN><SPAN class="punctuation token">,</SPAN> options<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">new</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN>old<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> context<SPAN class="punctuation token">:</SPAN> nil<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">override</SPAN> func <SPAN class="token function">observeValue</SPAN><SPAN class="punctuation token">(</SPAN>forKeyPath keyPath<SPAN class="punctuation token">:</SPAN> String<SPAN class="operator token">?</SPAN><SPAN class="punctuation token">,</SPAN> of <SPAN class="keyword token">object</SPAN><SPAN class="punctuation token">:</SPAN> Any<SPAN class="operator token">?</SPAN><SPAN class="punctuation token">,</SPAN> change<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>NSKeyValueChangeKey <SPAN class="punctuation token">:</SPAN> Any<SPAN class="punctuation token">]</SPAN><SPAN class="operator token">?</SPAN><SPAN class="punctuation token">,</SPAN> context<SPAN class="punctuation token">:</SPAN> UnsafeMutableRawPointer<SPAN class="operator token">?</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="keyword token">let</SPAN> mapViewThatChanged <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">object</SPAN> <SPAN class="keyword token">as</SPAN><SPAN class="operator token">?</SPAN> AGSMapView<SPAN class="punctuation token">,</SPAN> keyPath <SPAN class="operator token">==</SPAN> <SPAN class="string token">"mapScale"</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="token function">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Map scale changed to \(mapViewThatChanged.mapScale)"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
or if you're using Swift 4, it might look like this:
<SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">var</SPAN> scaleKvoToken<SPAN class="punctuation token">:</SPAN>NSKeyValueObservation<SPAN class="operator token">?</SPAN> <SPAN class="keyword token">override</SPAN> func <SPAN class="token function">viewDidLoad</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> super<SPAN class="punctuation token">.</SPAN><SPAN class="token function">viewDidLoad</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> scaleKvoToken <SPAN class="operator token">=</SPAN> mapView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">observe</SPAN><SPAN class="punctuation token">(</SPAN>\<SPAN class="punctuation token">.</SPAN>mapScale<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> mapViewThatChanged<SPAN class="punctuation token">,</SPAN> _ <SPAN class="keyword token">in</SPAN> <SPAN class="token function">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Map scale changed to \(mapViewThatChanged.mapScale)"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
